That is correct. The engine codes were unique based on engine configurations for each model year. Every time an engine had to have a different part of configuration as a result of an option (or lack of option) it got a different engine code.
The one that also fascinates me are the 1966 engine codes with three characters where the last character is either an R or an H to represent either Rochester or Holley carburetor type to be installed. I spoke with a man that worked at the Flint engine plant in 1966, and he told me that the engine configuration difference between those two engines was the mounting studs for the carburetor for the Holley carb, and no mounting studs (I think I have that correct) for the Rochester carb. The Rochester carb was held on with bolts if I recall correctly, so they would be installed at the time the carb was installed.
And I am sure that even after five editions, there are still discrepancies in The Lime Book.
