65 Corvette tele turn signal switch - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    When I tighten the steering column hub nut over the turn signal switch it appears to have the hub pressing on the switch assembly causing the top and bottom switch halves to separate causing the switch not to work. The switch screw in the back remains tight. This happened several times and I am wondering if my hub spring is too weak causing the hub to push on the switch? I am torqueing the nut to 40 inlb.
    ​​​​​​​Dave K.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 65 Corvette tele turn signal switch
    Dave not sure if it'll help as it's a bit busy but here are the prints for the column. You'll have to zoom in for detail of the hub and switch area.
    Rich
    https://www.forums.ncrs.org/attachme...2&d=1618826986
    https://www.forums.ncrs.org/attachme...1&d=1618826986
    • Dave K.
      • November 1, 1999
      • 951
      Rich,
      Thanks.
      Dave
      Rich
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Dave do you have John Shea's info pages?
        • Dave K.
          • November 1, 1999
          • 951
          While the tele steering column was out of the car I examined the old turn signal switch and compared it to a new one I had just purchased. I noticed that the two sponge wipers were missing from the old switch. I assume that these wipers are to keep the horn contact under the cancelling cam clean? I borrowed the wipers from the new switch and installed them in my old switch. Reinstalled the remaining parts and the hub and performed a continuity check on all of the appropriate connections and it passed all of the tests (stop light, RH turn, LH turn). Reinstalled the column and and everything works except the left side instrument blinking turn indicator.
          Dave K.
          • Dave K.
            • November 1, 1999
            • 951
            Correction!! Left front TS light not working. I would assume that this would prevent the inside cluster bulb from flashing?
            Dave
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              Dave
              Dave, Correct as both are from the same source... TS switch.
              Does it light, but not blink?
              You'll have to check for voltage at the front directional lamp socket. Double check the 3 connections...
              1- underdash connector
              2- bulkhead connector
              3- wheel well plug
              Rich
              • Dave K.
                • November 1, 1999
                • 951
                Connection at accordion connector was loose. However, now I must hold the turn signal lever hard left to get the inside cluster light and outside LF light to blink. I did no heat fuse the lever to the plastic switch housing.
                Dave K.
                • Dave K.
                  • November 1, 1999
                  • 951
                  I must hold the lever hard left to get the left inside and LF front bulbs to work.
                  Dave
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Dave it appears the internal contacts are a problem. If you can open it up you may be able to correct it. If you get it apart post some photos.
