I hope this isn't redundant as i tried to add it to the Muncie archived posts.
I ran across this from 5speeds.com by Paul Cangialosi. Watched a lot of his Muncie videos and he is what i would say is one of the best experts with knowledge and rebuilding the Muncie the correct way. Check out his videos.
The info he provides on his website is an invaluable tool so i wanted top share it with ya's.
Food for thought.... Also learned the "P" does not stand for passenger car as a lot of people think.
Main Case
Main Case
| 3831704 | 1963 Only small 6207NR Front Bearing ,Pat. Pending, 7/8" Bore |
| 3839606 | 1963 - 1964 Regular Bearing Pat. Pending, 7/8" Bore |
| 3851325 | 1964 -1965 7/8" Bore Patent Pending Mostly 1964 |
| 3851325 | 1964 –1965 7/8" Bore Patent Number |
| 3864848 | 1965 7/8" Bore Patent Number ( rare ) |
| 3864_____ | 1965 Milled off last 3 digits 7/8" Bore Patent Number |
| 3885010 | 1966 -1967 1" Bore Patent Number |
| 3925660 | 1968 – 1970 1" Bore Patent Number |
| 3925661 | 1969 – 1974 (some early 1975 cars) 1" Bore Patent Number |
Tailhousing
| 3831731 | 1963 "Thin Fin Tail" Driver speedo 27 spline |
| 3846429 | 1963 "Thin Fin Tail" Driver speedo 27 spline |
| 3846429 | 1963-1965 Regular thick web, driver speedo, 27 spline Used up to 1970 in some Pontiac Models |
| 384362 | 1963 – 1964 Long Tail Driver Side Speedo 27 Spline |
| 9779246 | 1964 – 1965 Pontiac Catalina Long Tail Pass. Speedo 27 Spline |
| 3857584 | 1966 – 1970 Passenger side speedo, 27 spline |
| 3978764 | 1970 – 1974 passenger speedo, 32 spline output |
Side Cover
| 3831707 | 1963-1965 Early side cover stud type shift shafts |
| 3884685 | Cover issued with "584" tail stud type shift shafts |
| 3950306 | Short boss with bolt on type shift shafts - no switches |
| 3952642 | Long boss bolt on type w/ TCS switch on 3-4 |
| 3952648 | Short boss bolt on type w/ TCS switch on 3-4 |
| 335308 | Long boss bolt on type with neutral safety switch. Some have a boss for the switch that is cast but not machined on 1-2 Case casting numbers, relating production years and ratios available Casting: 3831704 Years: 1963 Only Ratios: M20 2.56 1st , M21 2.20 1st Casting: 3851325 Years: 1964 - 1965 Ratios: M20 2.56 1st , M21 2.20 1st Casting: 3885010 Years: 1965 - 1967 Ratios: M20 2.52 1st , M21 2.20 1st, M22 2.20 1st Casting: 3925660 Years: 1968 - 1970 Ratios: M20 2.52 1st , M21 2.20 1st, M22 2.20 1st Casting: 3925661 Years: 1970 - 1974 Ratios: M20 2.52 1st , M21 2.20 1st, M22 2.20 1st Ratios of the M20 , M21 , M22 Year 1963-1965 Type: M20 Rings: None Ratio: 2.56 / 1.91 / 1.48 / 1.00 / 3.16 Year 1966-1974 Type: M20 Rings: Two Ratio: 2.52 / 1.88 / 1.46 / 1.00 / 3.11 Year 1963-1974 Type: M21 Rings: One Ratio: 2.20 / 1.64 / 1.28 / 1.00 / 2.27 Year 1967-1974 Type: M22 Rings: None Ratio: 2.20 / 1.64 / 1.28 / 1.00 / 2.27 Input Shaft Tooth and Spline Count Related to Year Year 1963-1965 Type: M20 Rings: None Spline: 10 Tooth Count: 24 Year 1966-1970 Type: M20 Rings: Two Spline: 10 Tooth Count: 21 Year 1970-1974 Type: M20 Rings: Two Spline: 26 Tooth Count: 21 Year 1963-1970 Type: M21 Rings: One Spline: 10 Tooth Count: 26 Year 1970-1974 Type: M21 Rings: One Spline: 26 Tooth Count: 26 Year 1967-1970 Type: M22 Rings: None Spline: 10 Tooth Count: 26 Year 1969-1974 Type: M22 Rings: None Spline: 26 Tooth Count: 26 Please note that there are 7 different Muncie input shafts. All 26 spline inputs came with 32 spline output shafts and all 10 spline inputs came with 27 spline output shafts. A common mistake is thinking that all "fine spline" 26 spline input shafts are M22 heavy duty types. This is not true. An M22 gearbox has a 20 degree helix angle on the gearset as opposed to a 30 degree angle. It's roughly a 10 degree difference. From time to time I get people disputing what exact angles are on the gears. Personally, I think the angles vary from gear to gear. 1st gear on an M22 may be 19 degrees, 3rd may be 20 degrees. Also M22 gear sets were of a higher nickel alloy. The straighter angle was designed to produce less end loading of the gear train and less heat but created more noise, thus the nickname "rockcrusher". The higher nickel alloy allowed for more impact of the gears. Another misconception is if you have a drain plug you have an M22. Again this was only true when the first M22 boxes were created. But all 3925661 castings had drain plugs. Reading Serial and VIN Numbers Serial numbers for Muncie 4 speeds always begin with the letter "P". P stands for Muncie Plant. Not for passenger car as some self proclaimed specialists may think. The letter M was used to ID the Muncie plant for the Muncie 3 speed, so P was the next logical letter. The letter O would add confusion since it resembles zero. The serial number is a date code the transmission was built for a particular year. Serial numbers from 1963 to 1966 included only the month and day. P0101 would indicate January 1st. From 1967 to 1968 the serial number got a year designator and a letter designator for the month such as P8A01, meaning January 1st 1968. One important point is that if you have a Muncie dated with a December build date it was actually built the prior year. An example would be the date code P8T13. This is for a 1968 production car. The T stands for December and 13 is the day. To confirm this simply look at the VIN number. It will usually begin with a 18S101350 or a 28N12950. This means the Muncie was assembled December 13, 1967 for the 1968 model year. The VIN number will usually be a low number. 1969 to 1974 Muncies got a ratio designator at the end of the serial number. An example would be P4D23B. This equates to April 23, 1974, M21 ratio. Month Code Chart February Letter: B June Letter: H October Letter: R March Letter: C July Letter: K November Letter: S April Letter: D August Letter: M December Letter: T Ratio Code Chart Letter: A M20 RatioLetter:B M21 Ratio Letter: C M22 Ratio Important Notes Some input shafts produced by the aftermarket and General Motors have no identifying rings on them. The rings originally corresponded with rings or grooves on the counter gear so that the assembler matched a one or two ring input with a one or two ring cluster. When manufacturing was stopped, GM stopped making inputs with these marks, probably to save machining operations. Also 3831704 and 3851325 castings come with a 7/8" counter shaft all others come with a 1 inch counter shaft. There are some odd ball castings out there produced in 1963 to 1966 years. I've left them out since they really are not common. |
