Re: C2 Replacement Holley-wont clear to idle
Very interesting. What were you using as lubricant on the pad? I take it you did not replace the weights?
Work the shaft mechanisms so the blades find their centers in the bores and tighten the screws. Check for free movement from full open to full closed. Reassemble.
