Is it true that the distribution block (db) is merely to trigger a switch in the event of a brake fluid problem? Is it true that if the shuttle valve is tripped, one cannot bleed brakes until the valve is recentered? Do I need the recentering tool when bleeding brakes even if the valve is centered?<br />
All brake bleeders are gravity bleeding just fine and I do not have brake light showing on dash. As such, does that mean the shuttle valve is centered and I do not need the tool to bleed the brakes.<br />
<br />
As an aside, brake bleeding has been a pita. I changed all calipers (rebuilt) and new master (3 of em ). Rubber lines are now braided stainless. No leaks detected anywhere. I did bench, buddy, and gravity bleeds. On other forums, I see that bleeding is not exactly a simple job. Cars been up on blocks for a month. Thanks for assisance. Ted 64289
<br />
