First, sorry for the sideways pic. I've looked at numerous pictures of the dash fit with other '69's where the wiper switch and chrome dash meet and they all seem to have some sort of fit like this where the console sticks out beyond the dash pad. First why is this and how is it corrected so there is a flush fit? The wiper switch hits the chrome trim and makes it tight to operate. Any help would be appreciated.
1969 dash console fit-are all like this?
Re: 1969 dash console fit-are all like this?
Steven------
The alignment of the bezel with the upper dash pad is typically not perfect. However, I think that yours is much further misaligned than any would have originally been seen. I suspect one of three causes: improper installation of the bezel, a distorted bezel, or a broken bezel. Broken bezels are common although they do not break in service. They break due to aggressive installation or removal.In Appreciation of John Hinckley- Top
Joe, thanks for the answer. I'm about to replace the dash pad, windshield and center console so I'll be able to see the damaged bezel and address it accordingly. I'll even post pics on what I uncover to help others with the same issue. Your expertise is beyond helpful. Thank you.- Top
It's not clear from the photo, but the instrument bezel looks like it may be broken on the passenger side. They're designed to breakaway in a collision just below the AC vents, and as Joe advised, easily break while handling.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
I would not guarantee a reproduction would fit as well as an original.
Having said that, you can usually tweak the alignment of the center cluster to fit better than you show here.Vice-Chairman (West), Michigan Chapter NCRS
Patrick, I would use the dash pad I have, but it appears that the pad is red, based on some dye that has rubbed off and in the right sunlight, you can see the red come through. I will look and see about an original dash pad, but what are the odds of that? I always try and use original but if anyone has ideas on a source for original dash pads, I'm ready to purchase.- Top
Mark Edmondson
Dallas, Texas
Texas Chapter
Hi Mark, I finally had some time and looked at the bezel and you're correct, the bezel is cracked on the right side. That will also be replaced when I take it apart or more accurately, when the interior guy does that part of it. Thanks for picking up something from a photo that I didn't catch right in front of me.- Top
Don't feel bad. I drove my first Corvette, a '73, for a year before I realized the two clean seams in the bezel, one on each side, were breaks. I thought it was a two-piece assembly.Mark Edmondson
Dallas, Texas
Texas Chapter
Usually I see the right side not fitting tight, never the left. However, any 68 -72's I have ever seen they never fit perfect. I have no clue why. In regard to the 1969 in question, for me it is not just the left side that I don't see fitting good, it is my opinion that there is too much space."SOLID LIFTERS MATTER"- Top
- Top
I believe I learned it from the service manual but need to check.Mark Edmondson
Dallas, Texas
Texas Chapter
