Re: Fuel Injection Fuel Meter Housing ID help needed
Well, wow!!!!! Just wow!!!!
Now I know there are at least two of these high volume pumps! One difference between the two is that the other pump has an aluminum end plate while yours has a traditional cast iron end plate.
Look in the vicinity of the stamped identifying figures. Is anything else stamped there beyond the normal "001" "Made in USA", etc?
Note that the shaft for your pump is correspondingly longer than pump shafts for normal pumps. Frank Antonicelli can make or have made a replacement if ever you need one.
Full disclosure: That "other pump" I've mentioned? It's mine.
