FI high pressure pump seal removal
Re: FI high pressure pump seal removal
That's a clever solution to the problem, Leo! Congratulations. I'm going to have to try that. I assume you insert the drill shank from the open end for the pump cable? I can't imagine how you could snake it through the two carbon bushings.
FWIW, I've never had any success with the tap method. I've made a puller out of some 1/4" rod stock. It works well on seals which haven't been epoxied in place. For epoxied seals, I use controlled violence and some very choice words.- Top
Thank you Jim, you are correct I did carefully inserted through the pump cable end. I understand the controlled violence and choice word statement also. I read your article in the restorer and found it very informative. I will be trying some of the things you discussed in your article..- Top
