C2 Cannot Remove Steering Wheel/Turn Signal Housing
Re: C2 Cannot Remove Steering Wheel/Turn Signal Housing
There is this document that I've gone by for a lot of the torque settings...
It agrees with Norm's specs above @ 30 ft-lbs...Attached Files- Top
I'm a bit suspicious of a couple of those values. For years I've had a card with "standard torque values" based on shank diameter and grade. In the event I can't find what I consider to be a reliable torque spec in the service manuals or AIM I use the card value.
I'm sure there are charts on the Web with the same info.
Duke- Top
