Re: Duntov Cam Performance
If it's an original 302 Z-28 engine the cam was the 30-30. Those 302 Z-28s barely qualified as a "muscle cars". With standard 3.77 axle and CR four-speed they ran the quarter mile in the low to mid 15s.
Short stroke and big cam = soggy bottom end, but they certainly loved to rev... to the point of bending pushrods and throwing rods. So depending on the block make it a 327 or 383.
My 340 HP (Duntov cam) SWC with a CR T-10 and 3.08 axle was pretty doggy down low and "came on the cam" in the 3500-4000 range. After I modified the spark advance map to 365/375 HP specs low end torque was much improved.
You mentioned a distributor number, but I don't know the specs. The spark advance map is critical to achieving the broadest torque bandwidth, and I recommend the aggressive 365/375 HP spark advance map as a good starting point for all OE mechanical lifter cams.
The Duntov cam's low lift can't take advantage of big port head's larger ports, which is why I would never recommend it for big port heads.
The LT-1 cam has similar low end torque characteristics as the Duntov, but more top end power, about the same as the 30-30 cam.
