How tight should I torque the throttleplate on my Holley carb? I had to have it repaired due to a crack.
Carb throttleplate torque
Re: Carb throttleplate torque
Keith
If you mean base plate to manifold, then 60 to 80 inch pounds. Link to Holley site:
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
Dave, I meant baseplate to carb. I had to take the baseplate off for repair. I think the carb to manifold should be closer to 60 as the natural vacuum from the engine will keep the carb in place. Thanks Keith- Top
The issue is not keeping it in place, vacuum leaks after the carb metering circuits will cause lean mixtures and really fight you setting the idle-(air introduced after fuel metering leans the mixture)
REMEMBER INCH /Pounds
The base plates with the correct drivers rear mount tab are difficult to locate. By late 71 and as far as I know all of 72 have the re-enforced version of the base plate with the "additional lump" connecting the rear throttle blade shaft boss to the rear drivers mount tab.
Keith, I had a phone explode and I lost your contact info - send me a text.James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
Keith
Throttle plate to main body is 25 to 30 inch pounds. Torque values are in that link above.
Sent you a text message. KThe issue is not keeping it in place, vacuum leaks after the carb metering circuits will cause lean mixtures and really fight you setting the idle-(air introduced after fuel metering leans the mixture)
Keith, I had a phone explode and I lost your contact info - send me a text.- Top
