C3 Rear Shock Rebuild - NCRS Discussion Boards
  • John S.
    • June 15, 2015
    • 505
    Does anyone rebuild these shocks or are there any bushing kits available that I can have pressed in ?? Certainly would like to get them back on the car for another 49 years of use !!
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    Re: C3 Rear Shock Rebuild
    Originally posted by John Sigmund (61302)
    Just dropped both trailing arms out of my ‘73, the right rear bearing was starting to show signs of wear/movement.
    Everything came apart amazingly well and it appears to be the first time any work has been done to the rear suspension. I’ve got a number of small pieces that I will be replacing, the trailing arms will probably go to Bair’s for a complete rebuild. I’ve got new bolts, shims and strut rod bushings also from Bairs but the one open issue I have is my original rear shocks. While the dampening action of the shocks feels great the top/bottom rubber bushings are certainly shot.
    [ATTACH=CONFIG]109917[/ATTACH]
    John------
    The lower bushings were once available from GM under GM #3735334 but are long-since discontinued. The original lower bushings were actually a one piece design whereas the aforementioned SERVICE bushings were 2 piece. However, once installed, the 2 piece bushings are equally functional and indiscernible from originals. Plus, they are much easier to install. The bushings are available from Corvette parts sources like Dr. Rebuild, etc.
    The upper bushings were never available separately from GM. As far as I know, they are not available in the aftermarket, either.
      • 6940
      John, Zip Corvette sells bushings for the shocks, they have the two piece rubber lowers and a one piece poly. Lower, and the uppers as well.
      • John S.
        • June 15, 2015
        • 505
        • James G.
          • August 22, 2018
          • 783
          maybe just rub some paint into the rusty areas vs complete repaint so they fit in better with your quite original car?
          James A Groome
          1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
          1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
          My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
          Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
          • John S.
            • June 15, 2015
            • 505
            • James G.
              • August 22, 2018
              • 783
              I love unrestored cars, kinda partial to ones with at least one chrome bumper.
              James A Groome
