TI Module Fender mount position 1969 427 - NCRS Discussion Boards
  • Mark S.
    • April 25, 2019
    • 94
    As I continue to detail the body of my 69 I see that the holes in the front fender for mounting the TI module are such that the orientation results in the fins being in a horizontal position. Although I see nothing on this in JM I do see the diagram in the Assembly Manual that looks like the orientation should be vertical, i.e. fins vertical.
    Is there a "correct" mounting position? These holes appear factory made but since I am judging the car I would like to make it correct before putting body back on the chassis.
    Any help is appreciated!
    Mark
  • Gary B.
    • July 31, 1979
    • 926
    Re: TI Module Fender mount position 1969 427
    I'll get a picture for you tomorrow. To dark out. Have a 69 in the pole barn I can get a picture of...
    Gary B
    • Gary B.
      • July 31, 1979
      • 926
      Attached is a picture of the holes in the inner fender panel, from the wheel side. This is a K09 (June 9th) dated car.
      Hope this helps.
      Gary B
      • Mark S.
        • April 25, 2019
        • 94
        Yes the picture was very helpful. Thanks for sending... Much appreciated.
        Mark
