I'd like to get some opinions on using engine flush products to clean the engine internals of deposits accumulated over the years.
One example is this product - put in immediately before oil change and have the engine run for 10 minutes:
The underlying question to which I haven't found an answer is, if the engine can build up deposits (especially in the grooves of the piston rings and, thus, increase oil consumption) over 10 - 15 years when the engine is always thoroughly warmed up (overland trips longer than 30mls) but the car is used only in spring and summer and even then only every 3-4 weeks. The oil gets changed every two years.
Oliver
Oliver
