C3 Brakes? - NCRS Discussion Boards
C3 Brakes?
  • Renzo O.
    • December 11, 2021
    • 25
    C3 Brakes?
    I know the subject of lip seals vs O rings has been discussed here quite a bit, but....
    I have just acquired a 1969 L68 that is very near period correct and I am going to try to keep it that way as much as possible.
    With that said, I want it to be SAFE, too.
    Is there any point deduction for judging for any brake upgrades? If I go to Orings? If I swap calipers are there casting numbers I need to be considering? If I go to aluminum calipers? I have ordered the judging info, but I want to get to work on the brakes before it arrives so I can drive the thing a bit! The drivers rear is leaking pretty badly.
    Also, what about shocks, any point deduction for installing KYBs?
  • Mark E.
    • April 1, 1993
    • 4498
    Re: C3 Brakes?
    I would recommend using o-rings; the type of seal is undetectable. When judged, the casting numbers, and if visible, the stamped dates on the caliper are checked. If your calipers are original to the car, I recommend rebuilding them with o-rings. Lone Star Calipers has an "NCRS" service that restores your calipers with the original black finish and bare machined surfaces. Their "regular" service are exchange calipers painted grey all over.
    No advantage to aluminum calipers other than a nominal weight savings.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Don H.
      Moderator
      • June 16, 2009
      • 2236
      Re: C3 Brakes?
      Renzo
      welcome to the club and TDB..
      KYB shocks would receive a full deduction of Originality, and Condition points. Significantly dissimilar from original Delcos.
      • Renzo O.
        • December 11, 2021
        • 25
        Re: C3 Brakes?
        THANKS! Looks like they may have changed names or something... Is that Ken/SoCoolSpeedShop @ 803-829-8400 (??)
        • Renzo O.
          • December 11, 2021
          • 25
          Re: C3 Brakes?
          Thanks! Really appreciate it!
          • Mark E.
            • April 1, 1993
            • 4498
            Re: C3 Brakes?
            Are you asking about Lone Star Caliper? http://lonestarcaliper.com
            It looks like their website is undergoing maintenance today, but their phone number and email are listed.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
              Re: C3 Brakes?
