PVC-to-carb rubber hose; '66 327/300 base eng. - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 383
    What is the correct developed length of the black, thick-walled hose from PCV to carb base plate fitting? I've seen 17" on occasion, but that long would seem to make an ungainly large arc & thus stick out well beyond the air cleaner cover, et al. Thanks in advance.
  • Larry M.
    • January 1, 1992
    • 2688
    Re: PVC-to-carb rubber hose; '66 327/300 base eng.
    DR REBUILD shows 17 inches for this engine. But his hose also has the formed 90 degree end......along with correct ribs. I bought and installed this hose on my own car a few years back, and it fit perfectly without alteration (as I best recall).
    Check out his product............you will like it.
    Larry
