65 coupe torpedo light - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    Can the torpedo light bracket be installed on the clock bracket without removing the clock?
    Dave K.
  • James W.
    • December 1, 1990
    • 2640
    Re: 65 coupe torpedo light
    Yes, from the passengers side. Easier if the glove box is removed, but can be done with it in place.
    James
    Dave K.
    • Dave K.
      • November 1, 1999
      • 951
      James
      James,
      Both the glove box and radio side panel are out. Perhaps I can use a pair of long nose pliers to attach it to the clock frame.
      Dave K
      • James W.
        • December 1, 1990
        • 2640
        I've had to do that to both remove and install the torpedo light bracket on my '65 that has A/C.
        James
        James,
        Dave K
        • Dave K.
          • November 1, 1999
          • 951
          Thanks James.
          Dave
          • Michael G.
            • November 12, 2008
            • 2155
            Did it a few weeks ago. A real hand-destroyer with the glove box in place (lots of sheet metal edges to contend with), so I removed the glove Box and it was easy. Good luck.
            • Dave K.
              • November 1, 1999
              • 951
              Mike,
              I was fortunate as I had both the glove box and radio side panel off. It was easy to install.
              Dave
