I think the flywheel is part number 021 but what tooth count does the starter ring have. I think 168 but could 158. Anyone know? Thanks in advance.
1963 Flywheel
Re: 1963 Flywheel
Hey Jerry,
The part # is 3781021 and it is 153 tooth.
ToddAttached Files- Top
Re: 1963 Flywheel
There is no such thing as a Chevrolet 10.5in flywheel.
There are ONLY 12 3/4in with 153 teeth, or, 14in with 168 teeth.
The 153 teeth flywheels use a 10.5in clutch.
The EARLY (55-62) 168 teeth flywheels had a 10in clutch (replacements are now 10.5in). The 66-later 168 teeth flywheels use an 11in clutch.- Top
Re: 1963 Flywheel
Tom you are correct, I should have said 10.5 clutch disc. That’s what I meant.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: 1963 Flywheel
All Corvettes (and most other GM cars) from 1953 to 2019 used either a 153 tooth or 168 tooth flywheel or flexplate. Here's the breakdown:
1953-62 all---------------------------------168 tooth
1963-68 small block-----------------------153 tooth
1965 L-78----------------------------------153 tooth
1966-74 big block except L-88/ZL-1-----168 tooth
1967-69 L-88/ZL-1 with 4 speed---------153 tooth
1969 L-88/ZL-1 with THM-----------------168 tooth
1969-82 small block except ZR-1--------168 tooth
1970-72 ZR-1-----------------------------153 tooth
1984-96 all--------------------------------153 tooth
1997-2019 all-----------------------------168 toothIn Appreciation of John Hinckley- Top
Re: 1963 Flywheel
Thanks Joe. Please dont take offense...How sure are you of the weight? Reason I ask is I weighed mine on a scale and it weighed 27lbs. So I don't know if someone thru the years replaced it with another or what. I know the weight can make a huge difference in how the engine revs and launching the car and thru the gears so I want to make sure the weight is correct and what GM put on the 427 400 hp.
I am replacing the one I took off with a steel one from Ram Clutches. They have a few with different weights for diff applications.
when asking the technical rep, he states the closest they have to the stock weight is their 33lb when they also have a 25lb so now I'm needing proof of factory weight. Do you have such a document or manual that states that?
TIA!- Top
Re: 1963 Flywheel
Phillip-------Thanks Joe. Please dont take offense...How sure are you of the weight? Reason I ask is I weighed mine on a scale and it weighed 27lbs. So I don't know if someone thru the years replaced it with another or what. I know the weight can make a huge difference in how the engine revs and launching the car and thru the gears so I want to make sure the weight is correct and what GM put on the 427 400 hp.
TIA!
I actually weighed one on an accurate, beam type scale. However, I'll double check it when I get home from this trip.
Was there a GM casting number on the back of the one you weighed and, if so, what was it?In Appreciation of John Hinckley- Top
Re: 1963 Flywheel
Phillip-------
I'll be home Saturday and I can re-check it. Actually, it felt like it did weigh more than 22 pounds but that's what I thought I read off the scale. I'll confirm, though.In Appreciation of John Hinckley- Top
