Front clip �63 or �64? - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
  • James W.
    • December 1, 1990
    • 2640
    • Harry S.
      • July 31, 2002
      • 5258
      • Michael G.
        • November 12, 2008
        • 2155
        • David H.
          • November 11, 2009
          • 777
          • David H.
            • November 11, 2009
            • 777
            • Joseph S.
              National Judging Chairman
              • March 1, 1985
              • 831
              • David H.
                • November 11, 2009
                • 777
                • Harry S.
                  • July 31, 2002
                  • 5258
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    1964
                    1963
                    Also, here are the plastic hood blocks on a Feb '63 car. They fit against metal wedges mounted to the surround gutters.
                    In the above photo note the 2 holes for the metal wedges in the gutter near the tank. They were removed in that photo. Cars had 4 total in late February.
                    Later cars had the hood block holes filled as they did away with the blocks. They were used to keep the hood from rattling, but the engineers decided they were not necessary over time. There were several configurations of blocks iirc. None, then 2 then 4 then none..... or something like that.
                    Plastic blocks and metal wedges. Also note the gutters in that surround you photographed has no holes.
                    Rich
                    • Harry S.
                      • July 31, 2002
                      • 5258
                      Originally posted by David Hurd (51036)
                      C2 is new to me so forgive if this is an ignorant question but what do you mean by “hood block holes”?
                      David, just saw your question, please see post 10. Rich circled the four blocks. These were a 63 only part. When GM decided they no longer needed them they filled the holes with bondo/putty/plugs. Some of those hoods with the holes carried into 1964.
                      • Paul Y.
                        • September 30, 1982
                        • 570
                        It's a good life!
                        • Timothy B.
                          • April 30, 1983
                          • 5177
                          Originally posted by Paul Young (5962)
                          The inner fenders attached different on the 63 vs 64. A portion on the 63 had some foam attached instead of bonding strips on three sides to attach to the underside of the fenders.
                          Paul,
                          The 1964 inner fenders used the foam at the inner top, (front and back) the 1963 inner fenders used a bonding strip.
                          • Mark H.
                            • September 18, 2013
                            • 241
                            [QUOTE=Richard Mozzetta (13499) There were several configurations of blocks iirc. None, then 2 then 4 then none..... or something like that.
                            [/QUOTE]
                            Having nothing else to do, I went digging thru my back issues of The Restorer and found two articles by the one and only Loren Lundberg regarding these hood wedges. One in the Spring 1980 issue and a follow up in the Winter 1981 issue. As best Loren could determine in his research, they didn't start using the wedges until January 1963 and as Richard says, sometimes they used two, sometimes four.
                            • Harry S.
                              • July 31, 2002
                              • 5258
                              My April 63 Convertible has 4 blocks, My July 63 Coupe has no blocks, but the holes are plugged. Man it's cold in my garage.....
