Leaking Caliper Question - NCRS Discussion Boards
  • Paul A.
    • April 21, 2021
    • 227
    Discovered brake fluid under L front tire as I was jacking front end to do some work on exhaust flanges. Others are fine and I believe all 4 calipers are the same age, approximately 10 years now. Looking for an opinion. Should I service front together or just the leaking one?
  • James W.
    • December 1, 1990
    • 2640
    Re: Leaking Caliper Question
    If one is leaking, chances are the rest will follow. I would send both fronts or all 4 to Lonestar Caliper in Canton, TX. and have then sleeve them with stainless steel and o-ring seals.
    James
    I would
    • Paul A.
      • April 21, 2021
      • 227
      Thanks for that advise. When I did all 4 on my last 71vette, I had trouble finding Delco re manufactured. Anyone know of a rebuild shop located on Long Island NY?
      • Paul A.
        • April 21, 2021
        • 227
        Well not rebuilding calipers on car now. Aftermarkets anyway. Thanks all.
