C3 Trailing Arm Rebuild
Re: C3 Trailing Arm Rebuild
wow that is clean. What did you soak the parts in?Check out the NCRS Points Tabulator/Calculator Helper
Caretaker of 1971 LT-1 #16326 - Chapter Top Flight 2022
1971 LT-1 : Direct links to outside, interior & under dash, TI ignition parts
1971 LT-1 : Full date codes inventory- Top
Michael, all of the T/A components were blasted and refinished by Bairs. Prior to removal I soaked all of the nut/bolts down with Kroil penetrating oil. $30 a can on Amazon but it worked great.
F1E3E65F-E117-4C3C-AA6B-2BD67364A1E9.jpg1973 L82 M21 4 Speed, very original and well documented driver/survivor
NW Chapter Member, 2016 Bend Regional Top Flight
73/74 TIM&JG 3rd Edition Revision Team Member- Top
Nice - I was thinking it was Kroil - you can take apart old Steam Trains with that stuff!Check out the NCRS Points Tabulator/Calculator Helper
