correct finish for UPPER FRONT SHOCK WASHER? - NCRS Discussion Boards
  • John M.
    • April 18, 2017
    • 184
    What is the correct finish for the upper front original Delco shock absorber washer for a 1966 corvette? (February 22 build date) The JG notes that it is a light grey color - ? what does that imply. I am guessing a bare metal washer with some type of protective chemical coating but since I am going to be doing these it seems they should be done correctly. Anyone have knowledge or advice on treatment for this large, thick concave washer? (Guess that the nut is zinc or cad plated?) Thanks in advance!
  • James G.
    • August 22, 2018
    • 783
    Re: correct finish for UPPER FRONT SHOCK WASHER?
    I think they were dipped cad originally, I have used 95% zinc content primer for replication of such things in the past. .
    James A Groome
    1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
    1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
    My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
    Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
    • Gary B.
      • February 1, 1997
      • 6979
      John,
      I think you want GM 3790342, which is GM-discontinued. Joe Lucia posted this info previously.
        • 15573
        Originally posted by Gary Beaupre (28818)
        John,
        [ATTACH=CONFIG]110469[/ATTACH]
        I once bought a dozen of these from Chevrolet for a friend. ALL had a different shade of finish that ranged from light gray to almost black. What was the finish of the factory installed piece on the cars 50+/- years ago?? Good Luck!!
        • John M.
          • April 18, 2017
          • 184
          Thanks, everyone. Will Parkerize those washers this weekend. I appreciate your help.
          • Ron G.
            • December 1, 1984
            • 865
            John, I agree with Gary as I have some NOS upper shock washers and they are definitely gray phosphate.
            "SOLID LIFTERS MATTER"
              All-------
              So, how come a 3790342 part number on a part that was first used on Corvettes for 1965. That part number dates to way before 1965. Well, there was another application for this retainer. That application was 1962+ Chevy II.
