I just came across a deep groove pulley that has black paint on all areas except the front face. The recessed area on the front is also painted black. Did Delco paint these the same as the fan in some cases? It came off a 67 car. Thoughts? Thanks, KurtIMG_4422.jpgIMG_4423.jpg
67 Alternator pulley paint? Deep Groove 3829387
Re: 67 Alternator pulley paint? Deep Groove 3829387
I just came across a deep groove pulley that has black paint on all areas except the front face. The recessed area on the front is also painted black. Did Delco paint these the same as the fan in some cases? It came off a 67 car. Thoughts? Thanks, Kurt[ATTACH=CONFIG]110506[/ATTACH][ATTACH=CONFIG]110509[/ATTACH]
Kurt------
The only Delco pulleys I've ever seen painted were those that were part of an integrated pulley/fan assembly. In these cases, the pulley was always a stamped steel type pulley. I've never seen a machined steel pulley that was part of an integrated pulley/fan assembly.In Appreciation of John Hinckley- Top
To your point, Joe, the pulley on my late (June '67) L79 with C60 and N40 has a one piece integrated pulley/fan assembly #3909817... picture below.Kurt------
The only Delco pulleys I've ever seen painted were those that were part of an integrated pulley/fan assembly. In these cases, the pulley was always a stamped steel type pulley. I've never seen a machined steel pulley that was part of an integrated pulley/fan assembly.Attached FilesLeif
Top Flight 2017 Lone Star Regional- Top
My set up L79 w/N40. AlternatorIMG_4421.jpg 1100696 with 3843346 fan. I recently found this pulley for my application and was interested in the paint it had on it. I noticed the back side was also painted and had rub marks that match the 3843346 fan I have. The seller told me if came off a 67 Vette 435HP. based on the marks on the back, it was run with the correct 3843346 fan. Before I stripped the paint, I thought I'd ask the question, did Delco ever paint the pulleys to match the black fans?- Top
Kurt------
Not in this case. Leif's pulley is an integral assembly of pulley and fan and is part number GM #3909817. This is the correct assembly for his application.
The 3909817 is a 1967 released part and superceded GM #3875968 which was also an integral pulley/fan.
I have seen these assemblies finished in either black paint or black phosphate.In Appreciation of John Hinckley- Top
