1971 - Left headlight sticks for 2 seconds after right has fully opened - NCRS Discussion Boards
  • Mick D.
    • January 22, 2022
    • 159
    Hi folks,
    Am going for judging in April, and my left headlight sticks for 2 seconds before it lifts, I'm not sure if i would lose points for this, but i'm unsure how to troubleshoot.
    I'm pretty handy, but don't want to start messing with things, without researching it, as I am sure it has happened to others.
    Is there a headlight troubleshooting guide that anyone is aware of?
    Mick
    Check out the NCRS Points Tabulator/Calculator Helper
    Caretaker of 1971 LT-1 #16326 - Chapter Top Flight 2022
    1971 LT-1 : Direct links to outside, interior & under dash, TI ignition parts
    1971 LT-1 : Full date codes inventory
  • Mick D.
    • January 22, 2022
    • 159
    Re: 1971 - Left headlight sticks for 2 seconds after right has fully opened
    Just want to mention, I realize that there is a restoration database, I've been looking there before posting, but I didn't find what I needed, maybe i missed C3 headlight troubleshooting.
    • Mark E.
      • April 1, 1993
      • 4498
      First check for any mechanical binding with the door and it's linkage.
      Then check the system for vacuum leaks. There's some good guides in this TDB and CF how to do this. It's best to use a vacuum pump a couple of small vice grips to pinch lines and to check the system methodically. You may find leaking connections, actuators or motor. Not difficult just time consuming.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • James G.
        • August 22, 2018
        • 783
        If you use vice grips with the long jaws you can slip a piece of rubber hose over each of them so it is less likely you will damage the vacuum hose.
        James A Groome
        1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
        1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
        My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
        Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
        • Bob D.
          NCRS Shipping Data Report Manager
          • April 30, 1996
          • 785
          Michael
          I have a headlight vacuum troubleshooting guide, Send me an email at bdemmel34@gmail.com and I will email you a copy.
          Bob
          • David M.
            • September 30, 2004
            • 515
            s-l1600.jpgThey make a tool for that. Some are all injection molded plastic. This is a middle of the road set.
