Part# 5047991 is specified for later 1957 Corvettes. It is defined as "Slow Park".
Can anyone describe this technical functionality of this motor, Slow Park versus Fast Park(5047984)? Is this slow park function noticeably different enough to be seen visually, e.g. in a PV?
From the 1962 P&A catalog....
Also for reference from Wilcox Corvette....
1956-1982 Corvette Wiper Motor Numbers
| 1956e | 5047799 | early |
| 1956 | 5047924 | Front cover has no plastic actuator switch; it has a flat metal slide. Access to the back side upper left cover attaching screw is thru a hole in the mounting arm. |
| 1957e | 5047984 | s/n 1400 984 was fast park. 991 is a slow park design. |
| 1957 | 5047991 | slow park des. Dec 1957and later Dec. of 1957 and later cars only |
| 1958 | 5044266 | came with a new internal style switch design.. Better |
| 1959 | 5044266 | came with a new internal style switch design.. Better |
| 1960 | 5044266 | came with a new internal style switch design.. Better |
| 1961 | 5044266 | came with a new internal style switch design.. Better |
| 1962e | 5044266 | s/n 2000 came with a new internal style switch design.. Better |
| 1962 | 5044479 | changes to this motor were: a plastic coated internal wiring and phillips screws on the actuator stand. |
