1965 Survey Question: Rear trailing arm brake clips - NCRS Discussion Boards
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 969
    1. The last five digits of your serial number.
    2. Whether this brake clip is on one or both trailing arms, and if only one, which trailing arm has this clip?
    Thanks!
    Tony Stein
    1965 manual coordinator
    NCRS No. 4600
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
  • Gary B.
    • July 31, 1979
    • 926
    Re: 1965 Survey Question: Rear trailing arm brake clips
    # 6412, RH side only.
    • Tony S.
      • April 30, 1981
      • 969
      Thanks Gary. I have car 07488, and I have the same clip on the pass side too. Tony
      • Chuck B.
        • August 31, 1987
        • 121
        Hi Tony. 3542 has the clips on both sides.
        Chuck
        • Tony S.
          • April 30, 1981
          • 969
          Thanks Chuck! That's fitting into the pattern. These are rare production features. They seem to have been used in December, 64 through February, 65 (before the introduction of the rear sway bar used with the L78 cars). Hopefully more members will contribute to this survey.
          Hope you are well! Tony
          • Joseph S.
            National Judging Chairman
            • March 1, 1985
            • 831
            Tony, 09128 has clips on BOTH trailing arms.
            Joe
            • Joseph S.
              • March 1, 1985
              • 831
              Tony, I also notice that the brake line to the caliper is shaped differently than the lines that don't use a clip. There is more of a 90 degree bend at the beginning of the line when there is a clip. Without the clip is more of a 45 degree bend.
              Joe
              • Stewart L.
                • March 1, 1980
                • 351
                No clips on 176xx and also none on 228xx
                • Mark F.
                  • July 31, 1998
                  • 1468
                  Tony,
                  Here's what you've gotten so far sorted by last 5 of VIN.
                  I can keep tally - or just email you the Excel file if you want to do it...either way, just lemme know...
                  thx,
                  Mark
                  • James W.
                    • December 1, 1990
                    • 2640
                    Tony,
                    I know you are looking at early production cars, but there are no clips on either trailing arm on '65 VIN 22095 equipped with L79.
                    James West
                    • Tony S.
                      • April 30, 1981
                      • 969
                      Thanks James!
                      • Tony S.
                        • April 30, 1981
                        • 969
                        Thanks Joe! Early February, 1965 car. That fits into the pattern. Tony
                        • Tony S.
                          • April 30, 1981
                          • 969
                          Thanks Mark!! You da' man! The pattern seems to be December, 1964 through February, 1965. When the L78 car was introduced in March, 1965, the rear sway bar was introduced and the need for the spiral wrapped rear brake lines began. A brake line with spirals couldn't be installed in these clips, so this feature must be pre-March, 1965.
                          Tony
                          • Andy C.
                            • April 1, 1998
                            • 117
                            Tony,
                            I looked at me restoration pics for VIN 21429. There were no clips when I disassembled the chassis. The car is an L78.
                            Andy
                            • Mark F.
                              • July 31, 1998
                              • 1468
                              Update:
                              thx,
                              Mark
