Re: 1969 Engine Wiring Harness Replacement - will not fire
I agree it is a long shot Rich, but that 2 volt drop is a puzzlement. The C3 battery being behind the driver's seat has the negative lead attached to the chassis right under the battery case, and thus a good high current negative connection to the engine is needed. The C2 battery in the engine compartment uses a negative connection directly to the engine (I think, but my knowledge of C2s is minimal), thus no jumper across the engine mount.
I own two functioning C3s with TI, and another one under restoration and you are right on that with TI the battery has to be fully charged or you are SOL. Some of the aftermarket TI amplifier boards complicate the issue. Your systematic instructions are wonderful though. Keep working at it and all will eventually become clear. This is a great example of one member helping another and is what NCRS is all about.
