Paint for A/C duct? - NCRS Discussion Boards
Paint for A/C duct?
  • John P.
    • August 31, 2002
    • 215
    Paint for A/C duct?
    I have made repair using Harry's suggestion of the OEM ductwork from EBAY- decent repair, wish I had seen the adhesive recommendation. Working with 60 year old plastic isn't much fun, but it did the job. I still need to add the border below.5A814833-0C04-4C5A-BEB1-CF0B8E06587D_4_5005_c.jpeg24F6838B-F866-46CF-B13B-ABAE9329FF25_4_5005_c.jpeg
    At any rate, after light wet sanding, I now have adequate repair. Am looking for suggestions for light paint coverage for the duct to blend in to the original material. I get that it won't show much, just need to get close.
    Thanks as always.
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Paint for A/C duct?
    John,
    Repair looks good. does need to be strong. But it is much easier if you have paint equipment and reducers. I mix my own, but that's not always possible for others. So what I do is spray reducer over the sprayed area to melt in the overspray. Laquer thinner works best, but you have to have a way to spray it!
    otherwise take your chances with the rattle can and put up with the edges of your paint patch (overspray).
    Dom
    • John P.
      • August 31, 2002
      • 215
      Is a gloss black from any vendor a reasonable choice? Any preferences?
      • Domenic T.
        • January 29, 2010
        • 2452
        John,
        Not gloss black as your vent looks line it is between flat and satin finish.
        Dom
        • David G.
          • May 31, 1980
          • 274
          Originally posted by Domenic Tallarita (51287)
          John,
          Dom
          Except for 63 ducts which are an odd shade of green.
          • Frank C.
            • August 31, 2003
            • 170
            John,
            You have done a great repair job! One other option i would try given I was in your situation as an alternative to touching the area up w/paint is continued wet sanding with finer and finer grit, then polish compounds to blend area w/original. A good exemplar is polishing headlight covers that are scratched and or dulled yellow. My rationale is this might be a longer lasting alternative to blending paint on a surface that was not painted originally.
            Good luck, and hope you post the final product. Again great job!
            Frank
            Frank Clark
            U.S. Army Retired, current serving DoD Civilian
            C1 1962 300hp, 4spd. Black/Fawn
            C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
            C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
            C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
