1966 stamp pad opinions please - NCRS Discussion Boards
  • J W.
    • January 1, 2004
    • 62
    Do the characters and font and broach marks look legit on this 1966 stamp pad? One photo was during the rebuild and two photos are post-rebuild.
  • Gary B.
    • February 1, 1997
    • 6979
    • J W.
      • January 1, 2004
      • 62
      Re: 1966 stamp pad opinions please
      Gary, I am not sure what was done to the pad in the third photo, other than cleaning to remove grime, gasket material, etc as part of the rebuild.
      • Patrick B.
        • August 31, 1985
        • 1986
        The 6 in the Tonawanda stamping and the 4 in the vin stamp do not look typical of Tonawanda and St. Louis.
        • Larry M.
          • January 1, 1992
          • 2688
          Michael:
          Pat is one of the best on this subject, so take his advice seriously.
          Pat does not need any support, but I do agree fully with his assessment.
          Obviously, factory broach marks are also not seen.
          Larry
          • Mark F.
            • July 31, 1998
            • 1468
            What is the VIN and Body Build Date for the car this engine is in (unless it's a stand-alone engine)?
            thx,
            Mark
            • David H.
              • June 30, 2001
              • 1485
              Orange paint images: Does water pump casting appear to stand proud of stamp pad? If so, indication of decked block.
              Dave
              Judging Chairman Mid-Way USA (Kansas) Chapter
              • Roy S.
                Past National Judging Chairman & Concours Team ******
                • July 31, 1979
                • 1022
                Patrick, called it bad machine code stamp, bad vin derivative stamp, it is not GM/UAW work from the time period.
                • Michael H.
                  • December 1, 1987
                  • 724
                  Michael,
                  I would use Al Grenning services to verify the stamp pad.
                  Mike
                  • J W.
                    • January 1, 2004
                    • 62
                    • Gary B.
                      • February 1, 1997
                      • 6979
                      • Edward J.
                        • September 15, 2008
                        • 6940
                        I think someone like Al Greening also has a vast number of original engine stamps that may be able to verify/compare engine stamps, Mike’s engine stamp sure looks like a very aged stamp. The Stamps Gary posted is a great tool to use to see what stamps were used.
                        • Michael H.
                          • December 1, 1987
                          • 724
                          Originally posted by J Michael Wiater (41268)
                          Thank you for your responses! I thought the ‘6’ in the Tonawanda stamp looked odd too.
                          Michael,
                          Look at Gary's post of the stamps, bottom left hand side where the zero's are. That last stamp looks like a nine or it could have been used upside down as a six. So it's possible your six is a correct factory stamp used on your block. Al Grenning should have a list of engine stamp pads that match up to your engine build date that's why I would check with him. I also like the broach marks on your engine pad.
                          Mike
                          • Edward J.
                            • 6940
                            D42A3EA7-D0AD-4A7A-842B-EC746DFD505D.jpg Here is a great paper from one Al Greening classes I went to a few years ago.sorry about the rotated pic.
                            • Michael H.
                              • December 1, 1987
                              • 724
                              Michael,
                              Look at the 6 in these pictures. They are the same as yours.
                              Mike
