71 leaking something on to the garage floor after drive (was on tires)
Check out the NCRS Points Tabulator/Calculator Helper
Caretaker of 1971 LT-1 #16326 - Chapter Top Flight 2022
1971 LT-1 : Direct links to outside, interior & under dash, TI ignition parts
1971 LT-1 : Full date codes inventoryTags: None- Top
Re: 71 leaking something on to the garage floor after drive (was on tires)
It looks like engine oil. It appears your tire ran over what was already on the floor as you pulled into the garage. I doubt it is brake fluid as it looks very dirty for brake fluid. I have a base engine 1970 automatic. Its not trans fluid. The oil was not under pressure either. It really requires a visual inspection on a lift. Good luck.- Top
Agreed - engine oil. Was your Corvette parked more to the left before your drive and you didn't notice the drips upon leaving? Was anything else with an engine in that spot when the Corvette was out?- Top
Not sure why I did not think of that. Yes the car was parked more to the left - so it was actually already there when i pulled out I just never noticed it. I jumped to conclusions on this one. There’s probably a puddle more to the right now. Mystery solved! Thanks!
1971 LT-1 : Full date codes inventory- Top
