Fuel sender issues C2 - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 215
    my 1965 327/350 convertible fuel sender deteriorated beyond repair. I replaced it with the offering from LIC from several years ago-incorrect design, mediocre performance. Today I replaced it with a new item from Corvette Central-appears identical to the original. I tested it on the car before installing-worked perfectly.
    Problem now after filling tank and test drive: reading over 1/4 tank too low. If my reasoning is correct, I need to bend the shaft attached to the float, upward towards the rear deck lid of the car. The question is how?
    Has anyone had experience with this situation such that they have a technique to make the bend with the sender still mounted in the tank? I can get one arm into the tank, but no leverage. Any way to estimate how much to bend if I remove it from the tank? Trial and error is pretty time consuming in this case.
    Thanks for input.
  • John P.
    • August 31, 2002
    • 215
    Re: Fuel sender issues C2
    On second thought, it seems a sender reading too low should have the float lowered, so reading will be higher when at same fuel level.
    • Michael M.
      • February 1, 1993
      • 603
      Why don't you compare the bend to the old sending unit to see if they look the same?.
