I have 15-year-old R59 restoration battery that won't take a charge anymore. I recall an article about how to adapt a smaller AMG type battery in its case. does anyone know what issue it was in or a write up on how to do it?
taking apart a restoration battery
Re: taking apart a restoration battery
How to Restore an Old Car Battery | Eastwood Bloghttps://garage.eastwood.com
If you have an old car battery that has a low voltage output, it might be time to consider a small restoration project. Reviving worn- out car batteries is an important money and time-saver - and one that could save you from hardships in the future. Below, we take a look at how to refurbish a car battery and why it is so important.And when you get the choice to sit it out or dance
I hope you dance
- Top
Search for the DC12 article, your 67 will be the similar. I know it was mentioned, I asked, and have it on my to do list.
The issue I saw is that the cold crank amps of what was proposed were significantly lower than what the cca was for a dc12,
So since I don't need to have a car judged...the project waits.- Top
Here is the article you mention, actually two articles...pick your poison
Vinnie
Attached Images -
- Top
