C3 Battery reinforcement assembly - NCRS Discussion Boards
  • Gary S.
    • July 31, 1992
    • 1628
    Reference 1972 AIM UPC 12 Sheet A10 and item 5, "Reinf Asm", 3919636. I've seen the repro photos of this but can't find a photo of it installed. I have the proper 1.25 inch "pointy" bolt with E marking, maybe black phospate? but the underside of my battery box doesn't have a weld nut to secure the holddown, aka clamp, via the bolt 3858700. Is this item 5 actually under the body and does anyone have a photo of it? Right now my battery has nothing securing it .
    Thank you as always.
    Gary
    • 11608
    Re: C3 Battery reinforcement assembly
    There's a small bracket riveted to the fiberglass on the underside of the battery box.
    This bracket has threads that the bolt screws into.
    And, as you note, the aluminum rivets often corrode and the bracket falls off.
    I can see it in a couple of picture of my car (posted online). However, none specifically of the bracket.
    • Ray K.
      • April 30, 2005
      • 401
      Gary,
      The battery reinforcement assembly, (Item #5, GM #3919636) has a nut welded to it. It's attached on the underside of the battery box and held in place by two rivets (item #4, 9409245). When tightened, the "pointy" bolt (item #2, 3858700) retains the clamp (item #3, GM #3887588) and secures the position of the battery (along with clamp item #7, GM #3919633)
      The "pointy" bolt is black phosphate.
      My '71s at the shop and in storage right now, I can send pictures later this week (if nobody replies & posts the pictures before then).
      Ray K (#43777)
        • 11608
        If you Google "Corvette battery reinforcement" you will find a lot of photos of the part.
        https://www.corvettecentral.com/68-8...nt-rear-173014
        • Gary S.
          • July 31, 1992
          • 1628
          Ray, I would appreciate photos. Ray & Patrick, I asked because the bottom of my battery box is pristine as far as my limited inspection has shown.. I am, however going to jack it up and see if the reinforcement is really there and only the weld nut has surrendered to the elements. It's wet & cold and I haven't had the time to get full under there yet.
          • Gary S.
            • July 31, 1992
            • 1628
            Patrick,
            Thank you. However in my first post I mentioned I had seen the repro part. Further googling brought up original pieces for sale.
              • 11608
              Those rivets don't seem to take much to disintegrate, but I'll be interested to see what you find.
              • Mike E.
                • February 28, 1975
                • 5134
                Originals of the upper clamp are a lighter gauge steel than the reproductions, btw.
                  • 6940
                  Gary, here are some pic,s of my 72F3FB6DC8-1D52-4355-8F39-3C8CD3836DB8.jpg90FE207B-8824-4753-AD7C-FE44F6BD78E1.jpg37230FA2-7E88-4E03-8D68-80D499EEF617.jpg
                  • Gary B.
                    • July 31, 1979
                    • 926
                    Not the best picture, but you get the idea.
                    Gary B
                    • Gary S.
                      • July 31, 1992
                      • 1628
                      Great photos gents. Thank you. I'll jack the car up and crawl under to see what I have. I do have the clamp and bolt (mine is an "E" headstamp) but I'm guessing that the reinforcement is there because the rivets are still intact as viewed from the inside of the battery box. I'll post photos this afternoon
                        • 11608
                        You can probably just stick your phone under there and take a picture, and not have to jack it up at all.
                        • Ray K.
                          • April 30, 2005
                          • 401
                          Gary, Found these in my archived photos, shows the rivets and clamp.
                          Ray K
                          '71 Vette Battery Box Reinforcement - GM #3919636 - 112Apr22.jpg'71 Vette Battery Box Clamp - GM #3887588 - 112Apr22.jpg
                          • Gary S.
                            • July 31, 1992
                            • 1628
                            I know that, Patrick. But it gets a full "coming out of hibernation" makeover to include transmission and differential fluid check so as long as I have to jack it up for that ...
                            • Gary S.
                              • July 31, 1992
                              • 1628
                              Well, it looks like I could have saved some typing by crawling under there first. The reinforcement and rivets are all there but the weldnut is MIA. I am not sure if it shows but the bolt is an E.
