Will be installing the #3775762 GM bushings on my original strut rods(1 1/4) diameter. Could not
find an answer to my question upon researching this board. Here Goes>
Should the bushings be pressed in "Dry" or some Oil be applied to the the strut rod? Or perhaps some
modern day lube/penetrant like "CRS Freeze-Off" which makes the metal contract temporary before
returning back to normal be OK? Would this make the job easier? Comments Please>Thanks>Larry
