Reproduction Rubber Quality - NCRS Discussion Boards
  • Tom E.
    • June 1, 2019
    • 448
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Reproduction Rubber Quality
    Tom,
    I am very suprised you haven't mentioned the door and pilar seals.
    They are horrible - and - no way made from the materials that were on the GM prints.
    To diagnose, each as to be looked at separately, there have been a TON of junk ball joints sold over the years, some with off specs made in the USA that the supplier suggested 'put a washer under the nut to get fitment'....so unsafe. You would have to ID part numbers and suppliers to then dig into the details.
    Weatherstrips are made from epdm hard rubber versus latex foam or latex coated foam. No rubber supplier 15 years ago wanted to invest in the molds to make good pillar strips. I personally was going to, but as I saw no one really wanted to pay what it took to get a proper spec'd big block by pass hose...I backed off - the tooling back then was 35k.
    • Joe R.
      • July 31, 1976
      • 4547
      The first problem is using the words Reproduction and Quality in the same sentence. That does not exist! Notice in the catalogs when the words Made in the USA is used the price is higher BUT quality goes up!
      JR
      • David H.
        • June 30, 2001
        • 1485
        I'd say "Dr Rebuild" but most will miss the humor and the irony.
        Dave
        • Chris L.
          • January 1, 1994
          • 42
          He's an interesting character for sure.
          • Tom E.
            • June 1, 2019
            • 448
            JR
              Dave
              Dave------
              Dr. Rebuild has the best rubber products on the market today. Period.
              • David H.
                • June 30, 2001
                • 1485
                Dave------
                Agree, have used Dr for years on lots of parts - no issues ever.
                That's what I meant by irony - we've complained and in turn, lost a quality vendor.
                Dave
                • Tom E.
                  • June 1, 2019
                  • 448
                  Appreciate all the great feedback, certainly helped a lot. Like everything in life there’s always more to the story….
                  • Dan B.
                    • July 13, 2011
                    • 545
                    Dave
                    Good riddance !!!!!!!!!!!!!!
                    Check out Corvette Rubber Company for all your weatherstrip needs. Many restorations with their parts and they still look new years later.
                    I've never heard of ball joint or tie rod boot failures like that after only one year and presumably on a garaged car regardless of the manufacturer.
                    • Tom E.
                      • June 1, 2019
                      • 448
                      Yes, car is kept in climate controlled garage and driven about 900 miles. Certainly not enough to wear out any new rubber one would think. Just thought it was odd. I’ll pick up replacement boots from NAPA and install and move on. All my weatherstripping came from Corvette Rubber Co and that is holding up nicely.
                      thanks!
                      • David H.
                        • June 30, 2001
                        • 1485
                        ... Good riddance !!!!!!!!!!!!!!
                        And that's what I meant by missing the humor.
                        Dave
                        • Domenic T.
                          • January 29, 2010
                          • 2452
                          Tom,
                          I have a 67 coupe. Bought all rubber from LIC and ALL has crumpled!!. Bought another shifter boot and it was cracked when I got it.
                          I replaced emgcy cables because rubber was bad! new ones crumpbled! all other are cracked or gone! Car was never out of shop and not started!!
                          Dom
                          • Domenic T.
                            • January 29, 2010
                            • 2452
                            Harry,
                            Thanks my friend. I have a 67 435/427 that I did a frame off. My passion is my 63 coupe with the 327.
                            Dom
