67 clutch flutter - NCRS Discussion Boards
67 clutch flutter
  • Enzo C.
    • January 12, 2012
    • 533
    67 clutch flutter
    I installed a new clutch , throw out bearing ,and machine flywheel, last year and it works great .. the only issue is some clutch flutter when releasing the clutch on take off
    Not sure if this is normal and will eventually get smoother or something I live with ???
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Gerard F.
    • June 30, 2004
    • 3803
    Re: 67 clutch flutter
    Enzo,
    It might just get smoother with some wear. But--you might check your motor mounts for any looseness.
    Jerry Fuccillo
    • David M.
      • September 30, 2004
      • 515
      Ill assume you assembled it last year and have been driving it?
      Did it sit over the winter? If yes oil could be contaminating the assembly from a leak? Inspect the clutch & bell housing for evidence of oil splatter. If its slight it could wear in after a few miles. Do fix the oil leak source.
      Another possibility is the machine work (surfacing) was performed incorrectly or the shop did not use the correct surface grinding machine.
      Flywheels should always be ground with a stone, never cut on a mill or lathe.
      • Enzo C.
        • January 12, 2012
        • 533
        Enzo Colosimo
        ENZ-Z06/67
        • Bill B.
          • August 1, 2016
          • 303
          Enzo,
          How long between installation and started driving? I had assembled a new clutch disc and pressure plate on my body-off project and then it sat for over a year. When I started driving it, I had bad shutter on release. It got better over time, but it took a while.
          Suspect it was the clutch plate material that had made an impression (material transfer) onto the flywheel and pressure plate surfaces over time.
          Bill Bertelli
          Northeast and Carolinas Chapters Member
          '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
          • Enzo C.
            • January 12, 2012
            • 533
            I drove the car the same day ... maybe 10 miles on new clutch
            Enzo Colosimo
            ENZ-Z06/67
            • Daniel Y.
              • September 30, 2002
              • 185
              Are you sure it's the clutch? double check the differential tung . make sure the bolt that goes through the bushing on the cross member is tight.
              also could be you have the clutch rod too far out. does the cutch disengage near the floor or much further up?
              Dan Young
              65, 67 Duntov x2
              66 bowtie x 2
              71 LT1 TF
              90 ZR1 McCelland
              03 Anniverary
              06 Z06
              • Gerard F.
                • June 30, 2004
                • 3803
                Enzo,
                I've had a few clutches in my 67 and I remember always taking the car back for a clutch adjustment after putting some mileage on it.
                Maybe try getting a little wear and mileage on the clutch, and then take it back for adjustment. Maybe try some uphill speed starts and burn some rubber. Then adjust.
                Jerry Fuccillo
                • Enzo C.
                  • January 12, 2012
                  • 533
                  Hi Dan
                  After a little adjustment and driving a while it seems to be much better.. I guess its the break in procedure
                  Thank You
                  Enzo Colosimo
                  ENZ-Z06/67
