1963 in line Fuse question - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1273
    I had a faulty cigarette lighter and it fried the red power wire along with some of the main dash harness! No blown fuses in the block, so I guess I shut the power in time to save all the other harness's. I need to replace the main dash harness! in order to prevent future wire frying, I'm going to install an in-line fuse. First question...what amperage fuse would I put in that fitting?<br><br>Also, are there any other locations where I should put an in-line fuse in? Maybe the AMP gauge?? And again, what amp fuse would I use?<br><br>Thanks!
  • John D.
    • December 1, 1979
    • 5507
    Re: 1963 in line Fuse question
    Gerald, Many years ago I had a saddle saddle 63 fake fuel car. Late car with a early '63 unit on it. I pushed the cigar lighter in. Forgot about it. It did not pop out. Burnt all the wiring a some fiberglass. We should all have a fuse on that wire.
    I remember buying a dash wiring harness from Chevrolet. Headlight switch did not work right. Two of the wires in the harness were backwards.
    • Gerald C.
      • June 30, 1987
      • 1273
      John
      What size fuse would you put on this 14 gauge wire? Also, are a fuselinks the same?
      Jerry
      • Alan D.
        • January 1, 2005
        • 2027
        Gerald,
        A 14 gauge wire typically is good for 15Amps for a short distance. Think I used a 10Amp on mine, the 67 was fused and used a 20Amp.
        (You can also look at other year cars to see what was used)
        If you have a setup to test the lighter, try a fuse and assure the element heats up enough. PS, also burned mine up. Found it was easier to install the instrument panel with the harness already connected - so pay attention to how it was installed and save the old one since a few connectors may be different.
        • Gerald C.
          • June 30, 1987
          • 1273
          Thanks for the feedback. I guess I'm just thickheaded.....as I can't find an answer to this kind of simple situation. There is a 12 gauge wire coming from the cigarette lighter and I see that some responses say use a fuse link that is two sizes smaller..14 or 16??? I think the 15 amp fuse should work. But this is "clear as mud" ....
          • Donald L.
            • November 1, 1981
            • 140
            • Larry E.
              • 1652
              This topic comes up all the time. Question>What is the easiest way to install an inline fuse in
              the cigarette lighter circuit? Can this be done w/o taking out the whole cluster? Maybe somewhere
              around the fuse box where there is more room? Comments Please & Thanks in advance>Larry
              Larry
              LT1 in a 1LE -- One of 134
              • Joseph L.
                • July 26, 2012
                • 160
                Here is how I did my 1957. It uses the same connectors as the original and plugs directly into the lighter and wire.
                I fused the main wire from the battery to the ammeter in the same way. There were few fuses in the original design.
                Joe
                • Larry E.
                  • 1652
                  Joseph:Thanks for the reply; looks like a very nice installation idea. But how would one do this on a C2? How would you
                  install this? Pulling out the cluster or could this be done underneath? Thanks>Larry
                  Larry
                  • Alan D.
                    • January 1, 2005
                    • 2027
                    Also read the above thread https://www.forums.ncrs.org/showthre...ighter-removal
                    Great points!
                    • Gerald C.
                      • June 30, 1987
                      • 1273
                      Basic question about the fuse in an in-line fuse link.......15 or 20 AMP?
                      • Alan D.
                        • January 1, 2005
                        • 2027
                        I used the 10 AMP fuse (see post #2) however forgot how I calculated that current. So for caution start with the 10 AMP and see if that works for Op's
                        Rich Mozzetta did a nice write up on this called;
                        "Cigarette Lighter Fuse Holder for 1963 to 1966 Corvettes – No harness modifications"
                        See if you can find that one.
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11302
                          Yes, this one..... Here
                          • Gerald C.
                            • June 30, 1987
                            • 1273
                            I've already installed the in-line fuse link with a straight fuse line. Should I use a 10 amp or 15 amp fuse is the question.
                            • Leif A.
                              • August 31, 1997
                              • 3607
                              Gerald,
                              See if this answers your question:
                              https://www.oznium.com/blog/what-is-...ng%20over%2015.
                              A car cigarette lighter has a nominal voltage rating of 12 volts but is limited to 10.2 volts with a maximum current of 10 amps. It can efficiently function as an outlet in cars and is used to provide power to a wide range of devices, such as radios, mobile phones, and laptops.
                              Leif
