Need advice from you AC experts.
When Ibought my'67 with factory R12 C60 system in 2010, wasn't cooling. Found bad POA. Rather than buying a POA which may or may not work long, replaced POA with "POA upgrade" essentially a pressure reading tube and switch that cycles compressor on and off. Everything great till recently when sometimes long sometimes short cyclying. Old Air products said to replace just the switch. Did this and cyclying about right in length of time and pressures but won't produce vent air lower than 50 even though return "pipe" with the capillary tube attached is cold. Heater valve is not stuck open. Turning adjustment screw on switch doesn't help.We checked pressures before replacing the pressure reading electrical switch and seemed ok on freon but I can see bubbles in sight glass when compressor cycles on and off. Just low R12? I know proper way to check is to pull R12 from system and see if proper 3 lbs 4 oz weight, but OK if I just attach a can of R12 and watch vent temp as I add to see if low R12 is the problem.
Thanks for staying with me on this lengthy thread.
