Oil Cannister Assembly order - NCRS Discussion Boards
  • Shane B.
    Infrequent User
    • May 1, 2021
    • 14
    I have a 67 corvette and doing the rebuild on an oil cannister anyone know the order. I have copper washer on outside. Inside spring first then washer, rubber grommet, and cone. The lock ring or retainer clip does it go flat part up or down?
  • Donald O.
    • May 31, 1990
    • 1580
    Re: Oil Cannister Assembly order
    Shane,
    Before you assemble the filter, could you please measure the washer and rubber grommet for me? Since no one sells the rebuild kit anymore I am going to make do with what I can make. I just need their dimensions.
    Don
    • Stephen L.
      • May 31, 1984
      • 3148
      • Shane B.
        Infrequent User
        • May 1, 2021
        • 14
        Sure no problem
        • Donald O.
          • May 31, 1990
          • 1580
          • Shane B.
            Infrequent User
            • May 1, 2021
            • 14
            • Donald O.
              • May 31, 1990
              • 1580
              Not a problem.
              Don
              • Shane B.
                Infrequent User
                • May 1, 2021
                • 14
                The inside diameter of the flat washer on the outside of cannister is 5/8”. Outside diameter is an 1 and 1/4”. Rubber grommet is 1/2” inside diameter. Hope this helps
                • Donald O.
                  • May 31, 1990
                  • 1580
                  Good work Shane!
                  What is the outside diameter of the rubber washer(grommet)?
                  The only outside of the canister is the copper crush washer - right? Or did you mean the metal washer above the spring , below the rubber grommet? Is this to seal off the bottom of the cone?
                  Don
                  • Shane B.
                    Infrequent User
                    • May 1, 2021
                    • 14
                    I measured the outside washer and inside rubber grommet.
                    • Danny P.
                      • June 30, 2002
                      • 334
                      Shane, any automotive store carrys the cooper and rubber washer just have to match them up, 99% of time lower crush cooper washer leaks the rest of items you can reuse
                      • Shane B.
                        Infrequent User
                        • May 1, 2021
                        • 14
                        Ok. The other gentlemen was having trouble replacing his stuff. I got mine back together and in the car. I appreciate the info.
                        • Donald O.
                          • May 31, 1990
                          • 1580
                          Which automotive store?
                          I tried autozone, O’Reilly’s, napa
                          Don
                          • Jeff S.
                            • July 31, 1984
                            • 383
                            NAPA UP1245 for .516" ID copper crush washer for filter canister bolt. (UP1243's for .453" ID brake hose gasket, while you're there).
                            • Donald O.
                              • May 31, 1990
                              • 1580
                              Originally posted by Stephen Lavigne (7553)
                              The only parts I need are B and C
                              Don
