Distributor cap removal - NCRS Discussion Boards
  • Gerald J.
    Infrequent User
    • January 22, 2018
    • 22
    I had to remove all the plug wires from the cap on my '63 fuelie to get it off. All of the ignition shields are installed and there just doesn't seem to be enough slack in the wires to remove the cap with the wires attached. Am I missing something? Is there some trick?
    It has the short cap with the 90 degree wires.
    Jerry
  • Harry S.
    • July 31, 2002
    • 5258
    Re: Distributor cap removal
    Jerry
    Either the wire are cut too short or they are stuck in some of the holding brackets between the sparkplug and the cap.
    Have a peek ----> https://www.forums.ncrs.org/showthre...ire+length+327
    • Mike E.
      • February 28, 1975
      • 5134
      Disconnect 1,3,5, and 7 (or 2,4,6, and 8) and lay it to the side that still has wires connected.
      • Mark E.
        • April 1, 1993
        • 4498
        Would it be more like 2,1,8,4 or 3,6,5,7 ?
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 831
          Mike, That's the way I do it. I remove whatever bank is opposite the coil side. Then lay it down.
          • Paul Y.
            • September 30, 1982
            • 570
            Thats the way I do it but I number the ones I take off with a piece of masking tape easily removed
            It's a good life!
            • Mike E.
              • February 28, 1975
              • 5134
