Hello, A friend of mine recently purchased a 1972 Corvette with a 454 engine. I am doing a tune up for him. The plugs that I removed from the engine are AC Delco 41-817. The plugs that are required are AC Delco R45TS or 41-803. Are the 41-817 a hotter or colder plug than the 41-803? Would the 41-817 be more in line with a R46TS? The AC Delco sight is of little to no use. Thank you so much in advance for any and all help, John
AC Delco Spark Plug Heat Range
Re: AC Delco Spark Plug Heat Range
Original spec was the Delco ACR44T. I don't think there's any significant benefit to installing the fancy iridium, platinum, etc plugs – just use old-school nickel electrode tech. I use the NGK YR5 which cross references to the 44, 45 & 46 (I believe it's on the hotter end of the range; NGK uses an inverse heat range scale compared to ACD.)
- Top
I was looking at plug replacement options yesterday and found this. Don't know the source.Attached Files- Top
1970 454 uses R43T. 1972 may be different since it has open chamber heads; check the owners or service manual. I use one range hotter, R44T, because they don't foul as quickly. You can try a range or two hotter to see what works for your engine and driving style. The "S" suffix extended tip plugs (eg R44TS) work too; I haven't noticed a difference in performance.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
As a general rule AC heat range 5 or equivalent in another brand work best for normal road driving when the engine only sees brief periods of high load. OE plugs were typically heat range 4 for small blocks and 3 for big blocks.
The lower heat range OE plugs are more likely to foul than heat range 5.
If the ignition and fuel systems are in proper working order and unleaded fuel is used a set of "two-dollar" spark plugs should last at least 15K miles and maybe as long as 30K. I don't see the point of buying an expensive "100,000 mile" spark plug for a car than may only be driven for a few hundred to a few thousand miles annually.
Duke- Top
As referenced above, the called for spark plug is an R44T - both my P & A catalog and Delco book agree with this. However, I personally prefer the extended tip ( S ) plugs for street driving applications. In my opinion, the R45TS is what I would choose, but the R44TS should offer equal performance.
Ray- Top
1970 454 uses R43T. 1972 may be different since it has open chamber heads; check the owners or service manual. I use one range hotter, R44T, because they don't foul as quickly. You can try a range or two hotter to see what works for your engine and driving style. The "S" suffix extended tip plugs (eg R44TS) work too; I haven't noticed a difference in performance.- Top
- Top
To cite the '72 LS-5's R44T, I used the Specs doc that's downloadable from the GM Heritage Center. That pdf doc is invaluable in many ways and needs to be in everyone's arsenal of information.- Top
Thank you all for the information. I installed the AC R45TS, and it runs great. I still cannot find the heat range difference between the AC 41-803 and the 41-817. The manufacturers are not supplying the data they used to. Thanks again!- Top
(This NGK cross-reference is extremely detailed across brands.)- Top
