Cannot Find Correct Shifter Handle Bushing for 1966 - NCRS Discussion Boards
  • Philip D.
    Infrequent User
    • November 1, 1982
    • 7
    I just rebuilt my original '66 shifter linkage and went to install the T-Handle Bushings I got from Zip (ST-224); when installed the T-handle will not slide
    onto the shifter shaft even with the bushings lubricated. As you can see in the attached pictures, the replacement bushing, which is white, is too thick and too long compared to the original. I called Zip and they said they got them from Long Island and have sold 80 pairs with no problems reported. When I disassembled the shifter there was only one original bushing as opposed to two which is shown in the shop manual. The shifter handle is original equipment GM #3863363.
    Phil Downs 6013
  • Joe R.
    • July 31, 1976
    • 4547
    Re: Cannot Find Correct Shifter Handle Bushing for 1966
    Volunteer Vette Products is located in TN and offers corvette parts and accessories for your chevy from 1953 to 2013. Browse our site to find your part.
    Part Number SHO25
    • Mike T.
      • January 1, 1992
      • 568
      Phil - I've never found any of the new version bushings matching the old original bushings for thickness. I even tried using a sandpaper flapper in an illfated attempt to thin out the replacement bushing but no dice. Replacement bushing on the left, new bushing on the right.
      Mike T. - Prescott AZ.
      • Philip D.
        Infrequent User
        • November 1, 1982
        • 7
        Hi Joe,
        Does that Volvette part work as is, or do you modify it at all?
        Phil
        • Joe R.
          • July 31, 1976
          • 4547
          Phil, the bushing costs three bucks plus shipping. For that, take the chance!
          JR
          • Michael H.
            • December 1, 1987
            • 724
            [ATTACH=CONFIG]111653[/ATTACH][ATTACH=CONFIG]111654[/ATTACH][ATTACH=CONFIG]111655[/ATTACH]
            Phil Downs 6013
            Phil,
            I think your black bushing is a replacement as I've only seen white bushings on shifters. The repro unit maybe to thick and I thought they only used one bsuhing not two. If your going to lubircate the bushing a use synethic oil as a lubircant.
            Mike
            • Philip D.
              Infrequent User
              • November 1, 1982
              • 7
              Thanks, Mike. Your one bushing suggestion may be correct. Hah, my original bushing is white except for years of grime and discoloration.
              • Philip D.
                Infrequent User
                • November 1, 1982
                • 7
                I splurged, JR, and got the one from Volunteer which is the same shown by Mike Tarrant. Still doesn't work!
