P01 vs P02 - NCRS Discussion Boards
P01 vs P02
  • Blair K.
    • September 27, 2012
    • 170
    Re: P01 vs P02
    Originally posted by Tim Gilmore (16887)
    Blair, I want to keep them in the event I go back to rally wheels. I'm storing the trim rings and caps in them now.
    Thanks for replying back, Tim. Much appreciated. Keep me in mind if you change your mind. Money in hand. I will make it worth your while. Best Regards.
    • Blair K.
      • 170
      Re: P01 vs P02
      Here is a set of five PO1s' I picked up a couple of years ago for $350.00 (Canadian) plus the drive to pick them up. Pretty decent shape. Pointed fins.
      • Tim G.
        • March 1, 1990
        • 1358
        #18
        Re: P01 vs P02
        Certainly not bad for a decent set of five. Here are my never mounted PO2's.
        • Blair K.
          • 170
          #19
          Re: P01 vs P02
          Your PO2s' are very nice, indeed. Worth ever penny in my opinion...
          • David M.
            • September 30, 2004
            • 515
            #20
            Re: P01 vs P02
            Are the steel rings on the back side cap the same on P01 & 2?
            Mid 60s up into 72,3ish IMO is another automotive mile stone. Never again will you see hubcaps with cast pieces screwed into stainless rims that weigh 10lbs ea. 10 on the cool scale. edit>(actually 7-8lbs)<
            I had quite a cap collection before I could drive. 300ish Most found on the road side in the vicinity of a pot hole. Some amazing engineering art!
            I shop for cool hubcaps as wall art. Chrysler had some beautiful caps. 66-7 Charger, 69 Barracuda, 69-70 LTDs to mention a few.
            P01 &2 are on that list...for a car not art. though I wouldn't mind hanging one up either.
            • Scott R.
              Infrequent User
              • October 2, 2021
              • 28
              #21
              Re: P01 vs P02
              Hi, If you want to sell them I have a december 67 build with tank sticker, came with PO1's but now I have PO2's . I am currently rebuilding the 427/435 motor, m21 transmission and 4-11 posi rear. My itention is to get it good enough for judging NCRS. Scott
              • Gary T.
                Infrequent User
                • April 30, 1994
                • 13
                #22
                Re: P01 vs P02
                Tim,
                Your cars looks great.
                I am looking for a set of "white wall" correct tires for my 70 based on my build sheet.
                What is the correct "width" of the white wall used back in 1970 and where did you get them?
                • Tim G.
                  • March 1, 1990
                  • 1358
                  #23
                  Re: P01 vs P02
                  The whitewalls were on the car when I bought it last May. They came from Coker Tire, here's the link.
                  Tires | Styles | Brands (cokertire.com)
                  • Dave S.
                    • August 31, 1992
                    • 2918
                    #24
                    Re: P01 vs P02
                    Originally posted by Gary Truzzolino (24385)
                    Tim,
                    • Gary T.
                      Infrequent User
                      • April 30, 1994
                      • 13
                      #25
                      Re: P01 vs P02
                      Thanks Dave, just what I needed.
                      • David M.
                        • 515
                        #26
                        Re: P01 vs P02
                        Hi All,
                        I went through this thread and corrected/edited some inaccurate info(from me).
                        In the last 2 years I've amassed quite a few of these finned turbine starburst sunburst caps from all makes, Ford, Chrysler, GM et al. Spinners and wire caps too. (definitely a diagnosed sickness).
                        I have ~3 dozen GMs, 15" Buick and Corvette, and a few of the 14."
                        Some NOS. Some early take offs, some nicely restored. I've learned how smooth out most dents and rash. Apply the black paint with the right sheen etc. Even got a hold of NOS center caps.
                        I can remove/replace old worn cracked faded cross flag medallions.
                        BUT I still don't know for 100% accuracy... Is the 1st picture in the first post in this thread chain an accurate picture of a PO1?
                        Blair Kaytar's picture of 5ea PO1s is too far away to see the details.
                        Can anyone provide me with good close ups of PO1s?
                        I need to see the details of the center cap, the fins and what the short fin looks like at the valve stem hole.
                        Part numbers would be helpful for the cast fins and center caps so I can confirm fakes from the real McCoy.
                        I believe the outer stainless rim is the same as PO2s?
                        There's a set of alleged "PO1s" for sale locally. But I think hes absolutely wrong they are definitely PO2s. The fins are squared off and the center cap is flush with the squared off fins...That to me = PO2.
                        TX
                        Dave
                        • Wes S.
                          • May 31, 1982
                          • 202
                          #27
                          Re: P01 vs P02
                          BTW P02 were available in 1973
                          • David M.
                            • 515
                            #28
                            Re: P01 vs P02
                            Thanks Wes. Correct 68, PO1 at least early cars. Then I think late 68 had PO2. Then 69-73 was PO2.
                            No hubcap options on 74-75, just std ralleys. Then the aluminum slotted wheel came in 76...I believe.
                            • Jeffrey A.
                              Infrequent User
                              • May 18, 2023
                              • 26
                              #29
                              Re: P01 vs P02
                              I also have question about the P02 for a correct restoration.
                              As far as I know the fins are black on the sides, but in the center on the area between the fins the surface is bare.
                              How was it painted from the factory? additionally what is the best way to reproduce this scheme?
                              Follow me: https://www.instagram.com/vintage_corvette/
                              • David M.
                                • 515
                                #30
                                Re: P01 vs P02
                                I believe its argent silver at the top of the cast fin area up to the center cap, (I call it the cone area).
                                Its definitely not bare cast. GM wanted some protection there. They learned from the Olds N93 and Riviera M9 RPO wheel covers that bare cast is not favorable. At least that's what I'm interrupting from the NOS PO2 I have.
                                There's a technique to getting the black and silver on right. If done wrong it stands out.
                                In the pics of one of my NOS PO2s you can see the definition line between the black and sliver.
                                Anyone know who manufactured these caps for GM... KH?
