C-1 caster and camber adjustment - NCRS Discussion Boards
  • Tim M.
    Infrequent User
    • July 14, 2012
    • 28
    When turning the upper control arm pivot pin to adjust the caster and camber with a bubble type gauge does the car have to be sitting with all the weight on the wheels? Should the 1/4 inch allen wrench turn easily? Seems like it would be easier with the tire off, or does this mess up the reading. Thanks.
  • Joseph L.
    • July 26, 2012
    • 160
    Re: C-1 caster and camber adjustment
    Measurements must be made with the suspension settled on the tires as if on the road. Caster and camber change with ride height.
