C2 Rear Bumper Bolts Torque Specs - NCRS Discussion Boards
  • Larry E.
    • 1652
    Replacing the non original bolts (markings on the heads) on my 66 Base Engine Coupe. I looked in
    the AIM and Service Manuals and could not find the "Bolt Torque Specs" for the Rear Bumpers. I may
    have missed them but does anybody know off hand? Thanks in Advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Leif A.
    • August 31, 1997
    • 3607
    Re: C2 Rear Bumper Bolts Torque Specs
    Larry,
    I've never seen, nor do I believe, there are any torque specs for bumper bolts. Just button them up tight...nothing crazy. The lock washers will hold everything place.
    Leif
    • Harry S.
      • July 31, 2002
      • 5258
      Larry, there is a sequence to bolt tightening. As I recall you start in the middle and work your way outward. This will help to not crack the fiberglass. If I have the sequence backwards, I'm sure others will chime in,
      • Larry E.
        • 1652
        Thanks Leif and Harry for the comeback. BTW>On the two bolts that connect the rear panel to the body of
        the car on each side; does the head of the bolt face the inner or outer part of the car? Thanks Again>Larry
        P.S. Something similar to the 68/69 C3 front Valance Spoiler where the AIM shows Head of Bolt facing the front
        but the assembly workers did the opposite for "their convenience". Thoughts??
        Larry
        • Leif A.
          • August 31, 1997
          • 3607
          Thanks Again>Larry
          Larry,
          If you're asking about the rear valance bolts (of which there are three per side) the bolt head faces to the outside of the car...nuts are to the inside...same as the bumper bolts.
          Leif
          • Larry E.
            • 1652
            Originally posted by Leif Anderson (29632)
            Larry,
            Leif: No not those. I talking about the two bolts/nuts(which I believe are bigger then the rest)>one on each end of the lower part of the panel.
            They connect the panel to the body fiberglass of the car. These Bolts/Nuts can not be seen from the outside of the car. Larry
            Larry
            • Harry S.
              • July 31, 2002
              • 5258
              Here ya go...
              • Larry E.
                • 1652
                Thanks to Leif and Harry for helping me again. Now onto my next project>Replacing the Front Parking Brake Cable.
                (Bought from Bairs Corvette) O how I wish a was a "Contortionist"! Project going good; right on target to get it judged
                next year. Picture of my car below. Thanks again>Larry
                Larry
                • Larry E.
                  • 1652
                  Just an added note on the bolts I replaced. The ones I took out where all over the place as far as head markings and size but on some
                  of the ones that looked awful original the head markings had an simple "R"nothing else which I did not see in the Judging Manual. All
                  where replaced with a "TR" head marking. Larry
                  Larry
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    Larry,
                    Can you post a photo of one of the R headmark bolts?
                    Gary
                    • Larry E.
                      • 1652
                      Originally posted by Gary Beaupre (28818)
                      Larry,
                      Gary
                      Gary>No Problem;will take picture of them tomorrow and post them. Larry
                      Larry
                      • Larry E.
                        • 1652
                        Larry,
                        Gary
                        Gary>Here is your picture of that bolt. Hope it comes out. Let me know what you think of it. Larry
                        Larry
                        • Gary B.
                          • February 1, 1997
                          • 6979
