65 headlight issues - NCRS Discussion Boards
65 headlight issues
  • Dave K.
    • November 1, 1999
    • 951
    65 headlight issues
    Installed a new aftermarket light switch (on/off), new dimmer switch, cleaned the radiator support sheet metal and added a star washer at the ground connection under the horn relay. However, light switch full out in dimmer low position, left side inner and outer headlights on bright. Dimmer in high position, all four headlights on but inner lights are dim.
    Dave K.
  • Brian T.
    • September 30, 1990
    • 188
    Re: 65 headlight issues
    Take a good look at the harness connection where the main headlight harness plugs into the headlight bucket extensions.
    • Dave K.
      • November 1, 1999
      • 951
      Will do.
      Thanks.
