Another project left to do before judging is to install the Original Damper Shock(378100) with
its original frame bracket. I noticed that this installation is very close to the exhaust side pipes.
Does this present any future problems with the heat involved? comments please! Below is an old
thread that went unanswered years ago. Please Read>
The end of the steering vibration damper where it attaches to the bracket that bolts to the frame on the driiver side on my L79 67' is 1/8th inch from the exhaust pipe (side pipes) just below the exhaust manifold. The exhaaaust pipe at this point is obviously VERY hot and is transfering a lot of heat to the damper! This is causing the damper to leak oil and deteriorate rapidly. Is this the normal location for the damper end or is something out of place. It may just be a bad design in which case I will wrap the pipe near the damper with some insulating material and forget about it. If it's wrong I would like to get it right!! Could someone with side pipes see if you also have this close fit between the driver side damper end and the exhaust pipe!? Thanks in advance!!
IF THIS PRESENTS A PROBLEM I NEED NOT INSTALL IT(DAMPER SHOCK) AND TAKE THE HIT WITH
THE POINTS FOR JUDGING. NEED SOME ADVICE FROM SOMEBODY THAT HAS CROSSED THIS BRIDGE
BEFORE. THANK IN ADVANCE>>LARRY P.S. My car is very very original and I noticed that that the frame
bracket is missing. I just wonder if one of the previous owners just took it off(The whole Damper System) if he was having an issue. ??
