Hello All. Just replaced the dash harness in my 1966 no ac L72 roadster. New harness is Lectric limited. Everything worked fine before I started the project, just decided to replace the dash wiring harness as I was getting the instrument cluster and glove box restored and since I already did all the other wiring harnesses, I thought I would the do the harness remaining.
Just got the restored cluster in and re-attached everything. (Except steering column and glove box.) Before I installed the steering column thought I would test what electrical I could. I realize a few things are powered through the steering column but was not checking those items. Car started up fine, windshield wipers work, gauges all work, headlight motors roll as supposed to, headlights hi and low work with the proper indicators on the cluster working when they are supposed to. Problem is my radio and heater fan does not work. On my fuse box I have no power on any side of the radio and heater fuses.
Everything looks solid from the engine compartment. Ignition and headlamp harnesses seem like they are attached fine to the fuse box at the firewall.
Any ideas would be appreciated. Thank You. Mark
