Can the tranny be removed without removing the engine? I would think the X brace would keep it from coming out. Thanks!!
1954 transmission removal question
Re: 1954 transmission removal question
Guy, in similar posts below is your answer. You will need a really good transmission jack and a screw jack to raise or lower the engine. Nothing is light it’s one heavy unit.I hope someone else has some input. The last power glide I did was a 63, and it was aluminum. I had to slide back as far as possible and then lower the front of trans to clear engine and frame. The screw jack was used to raised or lowered to clear engine Block.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Thanks Edward I appreciate that. The problem I'm having is when the car sits for 3 or 4 weeks fluid splashes out the dip stick tube at start up. Its not holding the fluid in the converter I think. It shifts great but this overflow situation has me stumped. Its something specific but I don't know what it is. Anyone else had this problem? The fluid is just backing up. Thanks for any input.- Top
Guy, I know that this situation has been brought here before. It surely sounds like a check valve if the converter is draining back it would make since the fluid would dump out the dip stick. I would look through the archives to see if you can find some info. I think the problem your going to find is someone experienced with the older power glides. Before you even start see if you can find a old timer that knows how to fix the problem. I know there are a few people here on the TDB that maybe of help.Thanks Edward I appreciate that. The problem I'm having is when the car sits for 3 or 4 weeks fluid splashes out the dip stick tube at start up. Its not holding the fluid in the converter I think. It shifts great but this overflow situation has me stumped. Its something specific but I don't know what it is. Anyone else had this problem? The fluid is just backing up. Thanks for any input.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Early 'Glides would burp like that if the vent was stopped up....I have some info on that somewhere....I'll see if I can find it...Joel Adams
1974 Coupe
1985 Coupe
"I know the voices aren't real...but sometimes they have some really kewl ideas...."
- Top
I have heard that it helps to shut down in reverse and start in neutral. I can understand the latter, but not sure why the former helps. But then, I don't super understand automatic transmissions. :-)- Top
