What is this bolt? (1963)
Available stickers: Engine suffix code, exhaust tips & mufflers, shocks, AIR diverter valve broadcast code.Tags: None- Top
Re: What is this bolt? (1963)
Pat about the only thing I can think of is the power steering control valve? The pinch bolt that holds it from rotating?New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed,
no power steering on this car, but I know the bolt you mean.Vice-Chairman (West), Michigan Chapter NCRS
Patrick,
Just a wild guess...since it's a convertible, could it be one of the bolts of this type that holds on the rear decklid's front Guide pins? Three per side. This is from my '73. Bolt appears to be about the same size and definitely smaller than the one at the steering box coupler. Not sure if the same type bolt was used in '63.Jimmy
1973 Convertible
L48,M20,N40
Mille Miglia Red/Oxblood
- Top
It looks like a bolt for aftermarket exhaust headers, those would be 3/8 coarse thread.- Top
No headers on this car.
Ed, I agree, nothing else comes to mind.
Jimmy's bolt is very close, so I'll have to look.
Currently, I'm not working on anything else so I have no idea how this bolt ended up on the table with the 1963 bolts. Usually I'm the guy who can look at a random fastener and tell you exactly where it goes on a car, so this is frustrating.
Thanks for the help so far gents.Vice-Chairman (West), Michigan Chapter NCRS
Generally 12 points in a GM are driveline related, Ujoints, steering shaft clamp at rag joint or reciprocating parts...unless its a Detroit Diesel in which case most fasteners are all 12s.
Here's where it goes:Attached Files- Top
Better pic, though not vette.- Top
It’s still not a steering coupler bolt. Please see my original post AND the tape measure.
If I were home I’d post a picture of the two together to show it’s about 60% of the size of a steering coupler bolt. Both steering coupler bolts are installed in the car; this bolt is not.
Jimmy’s convertible pin retainer bolt is the closest, but I don’t think it came from inside the car.
I can’t find any missing bolts right now, which I guess is good.
Patrick,
I own a 63 and while it lived a few lives before it came to me I have never seen a bolt like that other than the header bolts that were on the car. It's for sure not a steering couplier bolt.- Top
Thanks Tim.
It might not be from the 63, but with zero other projects in the shop right now I’m just puzzled.
As long as I don’t see any open bolt holes I’ll just set it aside for now.Vice-Chairman (West), Michigan Chapter NCRS
